I need to apply a load on a line (force per unit length) which should locally depend on the displacement of the line in a given direction; as for an elastic foundation.
Is there any way to realize this kind of mixed boundary condition along lines?
I actually found the solution: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS123556&lang=en&source=snippet
Thank you anyway! ![]()
