Stress Simulation - Max displacement value
COW
I have done simple stress simulation to check the max displacement of parts' blend amount from Y axis
It is shown the max_disp Y value is 37.69mm, but I see from the animate picture, the movement of parts is less than 3 mm. I had set the DISPLAY OPTION Scaling to 1
What does it mean of Max Displacement_Y value??
bschlosser
(To:COW)
The number in the upper left is 3.7e1.  It is the same 37 mm displacement as your annotation.  Are you referring to some other value or result that isn't shown?
