Symbols on drawings show up as boxes
JM_8847223
2-Explorer
I'm making a drawing of a model that was created by someone else. When I show the dimensions on the drawing - all of the symbols show up as square blocks.  The numbers are fine, but the symbols for diameter, counterbore, depth etc. all show up looking like square blocks. Anybody know a reason why?
llie
(To:JM_8847223)
We experienced the same issues. You will need to change the model and the drawing properties to the following. We made two mapkey for our users.
Drawing: set the symbol_font to stroked_asme
Driving model in drawing: set the symbol_font to stroked_asme
Sarvesh_B
(To:JM_8847223)
Hi @JM_8847223 ,
You can refer to the article CS265761 this might help you to resolve the issue.
Thanks & Regards,
Sarvesh
llie
(To:JM_8847223)
BenLoosli
(To:JM_8847223)
The boxes in place of text means that your computer does not have the font that the original was created with.
Are these TrueType fonts or a PTC font, like Font or IsoFont?
llie
(To:BenLoosli)
@BenLoosli  ours used to be isofont and we hand to switch to stroked_asme for drawing and non-mbd models.
For MBD models we had to use asme. It is a weird issue that PTC recognizes and fixed in Creo Parametric 7.0.10.0 I believe.
