I am modeling a throttle cable linkage mechanism and looking for methodology to incorporate the wire rope (cable) component. At one end is the throttle body with associated linkages and the other end is a throttle pedal with its associated linkage, both being connected by a cable.
Thanks for help...
This is an old tutorial but will set you on the path to modeling a cable.
