I would like to add contacts to my model. There is a part that travels up an down a rod following cam paths attached by a spring. I have a washer at the end of said rod, theoretically, keeping said "traveling part" from coming off the end of the rod. When I attempt to use the 3D contact feature I am not able to select the two surfaces that I am interested in.
I am fairly new to Mechanism so it's possible that more information is needed to respond. Please inbox me for any additional information and/or clarification.
3D contact is picky about the type of surfaces used. Take a look at this:
Hey Tom Thanks for the quick response! So attempting to create a contact between to planar surfaces was my issue. What if someone wanted to do this though, is there some sort of go around that your aware of?
You cheat. Make a spherical surface that is tangent with the face of your planar surface and use that instead.
