Hello
Looking at the possibilities of Creo 3.0 M080
I saw the possibility of having reactions.
Only I have a doubt on the units.
I have strength in [N/mm].
I have the Moment in [N]
It may be me who did not understand the principle of measurement.
Kind regards.
Denis.
Denis,
ok, you select what you want to display, and other other tab you select the desired units.
Force needs to be in Newtons N the fact that the window pops up all posible units it doesn´t mean it will be ok
that is all about
moment = N.m
hope this helps
Hello Antonio,.
Thanks for your reply.
I do not know if I understood your answer?
But for the Force, I have only married couples.
Kind regards.
Denis
