Hello.
Currently, I'm trying to insert inside my Creo Mechanism Analysis the effects of lateral wind. For this I would like to use a force so I can easily turn on and off for each analysis.
Would be nice to have it calculated using the cross-sectional area of the component multiplied by a constant Q (N/mm²).
How can I make available this measure of area (mm²) to the User Defined variables list?
Create a parameter using relation. In my case, the value is constant, so I can even do the equation in this step.
WIND_FORCE_BASE=AREA:FID_AREA_BASE*0.001
Inside Creo Mechanism, use Force, Function Type = Constant and instead of type the number for Coefficient A, type "WIND_FORCE_BASE", This will create a direct relation. Accept it and it is done. The amplitude of the Force is now related to the parameter.
One more way to do it:
Solved: Re: Creo mechanism - simulate load of braking cons... - PTC Community
