Vibration Analysis - Vibration Amplitude vs. Frequency
DV_10345470
3-Newcomer
I am trying to perform a Vibration Analysis on an assembly in Creo Simulate (in Creo Parametric Version 10). The only input data I have is the Vibration Amplitude vs. Frequency table below. I was wondering if it is possible to do an analysis in Simulate with this type of data. Is so, would it fall under the "Shock" category under the  "New Dynamic" analysis option? Or would it be under another category? An input on this matter would be helpful. Thanks.
YsnbKmy
(To:DV_10345470)
If  I were you, I will do as below.
1. Translete dispacement to acceleration.
2. Do frequency response analysis.
Hi @DV_10345470,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
