I would like to calculate the welding bracket correctly. But I have not yet found the right approach.
Or should I simplify the model first?
Load: 4kN
Thank you for your help. I didn't know that the rigid connection was defined in the part. 👌
Why did you delete the radius here?
I have started another experiment.
Here in the radius I have increased mechanical stresses.
precise bearings are important here
Hello, what do you mean by "precise bearings are important here"?
This console is only plugged in. The bore has a small oversize.
example:
can the axle turn?
Yes, the axle can turn.
OK, the axle can turn, what combination of materials is this?
Hi @ptc-2788381,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
Community Moderator
