Wildfire 3 - Slot Connections
ptc-179551
Can anyone help me with this. I am trying to connect a part onto a multiple segment curve in wildfire 3. In standard mode I can create a slot connection to only one segment of the whole curve. In mechanism mode I can not create slots at all. I can modify existing files in mechanism mode that already have slot connections to multiple segment curves. I just can't create new slot connections.
In WF3, slot connection is developed within the component placement dashbord, not in the mechanism mode as it used to be up to WF2. To answer your question, create a composite curve by copying the multiple segments you have. Hope that works.
