create lettering directorly in Sheetmetal model
bou
Could PTC develop a function which allow to create lettering directorly in Sheetmetal model?
Kevin
(To:bou)
Making assuptions, did you try unselecting the Remove material normal to surface option? Text that doesn't go thru the sheetmetal feature will have a problem bending if that is selected (first icon in following pic).
6 REPLIES 6
dschenken
(To:bou)
They could, but until then what sort of lettering are you interested in making?
bou
(To:dschenken)
bou
(To:dschenken)
Look at the red surface. You can try with any letter content. Only one requirement, the model shall be kept as sheetmetal.
Kevin
(To:bou)
bou
(To:Kevin)
TomD.inPDX
(To:bou)
Are you just trying to emboss a part number or something like that?
You could use graphics for this if you wanted.  You can make something called a decal.  And you can wrap curves onto the surface.
Just remember that sheetmetal prefers everything remain a single thickness.
