disable Windchill integration on Creo Simulate
AR
11-Garnet
11-Garnet
is it possible to disable Windchill integration on Creo Simulate.
I would like to use it outside of windchill
MartinHanak
(To:AR)
@AR wrote:
However, if I also use Creo Elemnts Direct Modeling, in the latter I have to put the windchill server back online every time!
And if I put it online in the workgroup manager, it is also online on Creo Simulate
find Creo Simulate startup file (file with psf extension) and add line similar to the following one at the end of file.
ENV=PTC_WF_ROOT=C:\PTC\Simulate_WF_ROOT
I hope this setting can separate Creo Simulate from Creo Elemnts Direct Modeling.
Martin Hanák
6 REPLIES 6
BenLoosli
(To:AR)
Should be able to by putting Windchill offline to your Creo session and working out of a disk work location.
AR
11-Garnet
11-Garnet
(To:BenLoosli)
MartinHanak
(To:AR)
Martin Hanák
AR
11-Garnet
11-Garnet
(To:MartinHanak)
It seems to work .....
I left your string even though Creo Simulate is installed on another folder ... okay?
MartinHanak
(To:AR)
YES that is OK.
FYI ... PTC_WF_ROOT variable specifies path to directory where Creo Simulate saves user "settings".
Martin Hanák
AR
11-Garnet
11-Garnet
(To:MartinHanak)
Perfect, by editing the simulate.psf file
adding the line:
ENV = PTC_WF_ROOT = C: \ tmp \ Simulate_WF_ROOT
