evalgraphs shown on drawings
petebruce
Follow up on the question... Can you show (on a drawing)
the graphs used in the evalgraph function?
In Wildfire 2.0 go to the upper pull down menu "Insert" and instead
of inserting a drawing view, choose insert graph.
Fairly straightforward, but after choosing the graph you
want from the list, when it acts like it hangs, it's waiting
for you to pick a placement point on the drawing.
Graphs can be moved and scaled just like a view.
Bruce Peterson
Great Plains Mfg.
Assaria, Ks 67416
p 785-667-7763 ext 3430
f 785-667-2695
http://www.greatplainsmfg.com
- - - - - - Original post - - - - - - -
I'm using several datum graph functions to drive several dimensions
in a variable section sweep.
Refresher example:
sd10 = evalgraph ("PROFILE_GRAPH", trajpar)
Has anyone displayed these graphs on a drawing for documentation
purposes?
I'll post a summary.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
