family table->merge/inheritance->family table
jstanczyk
We're having a discussion regarding the creation of a family-table model (casting), and then using the merge/inheritance function to create amodel (machined) which is modified with anotherfamily-table.
Therefore - one casting model (w/12 instances), one machining model (w/12 instances), 12 casting.drw's, 12machining.drw's.
Is this possible? Pro-E WF3 with AAX extension (nothing else). Thanks in advance.
bmozley
(To:jstanczyk)
Pro E users,
Is there a way to permanently hide or delete the 'common name' column in
the family table?
Brad
WF3
BRIAND.MORALES
(To:jstanczyk)
I spoke to PTC concerning the same issue in Wildfire 4. Unfortunately there is no method currently available to remove that column. I would be interested if someone in the Pro/E world has been able to find a workaround.
bmozley
(To:jstanczyk)
Pro E community,
Is there a way to hide or blank column(s) in a family table on a
drawing?
Brad
WF3
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
