fatigue analysis for creep range material characteristic
sguercilena
how can I configure the  material elastic stress limit and tensile stress limit of a SA 240-304H material at temperature of 740°?
The problem is that configuring material fatigue to UML, I only can insert yeld and tensile stress up to 100 MPa but at this temperature Sr100000h=28.28 MPa.
Is possible to perform a fatigue analysis in creep range with PTC Simulate?
I doubt it. What makes you think creep can be modelled in Creo?
I am not referring to the combination of damage to cycles of creep and fatigue, for this there are a lot of analitic procedure.
I just asked if there is the option to choose a different type of calculation for fatigue (no UML).
