I have a square block which i want to show it moving on two vertical guide rails like a elevator. i dont know how to apply a servomotor in this case. any help in this regard.
Regards
Sammy
I guess you are looking for this, as shown in the video (resolution is not so good). You have chose planner connection and select the linear axis of motion while select motion axis for servo motors. chanked the attached files.
Hi
Thanks for the reply. Actually i am trying to give motion to an elevator model so is it in any case possible to show a rope between the elevator car and counter weight which actually moves over a pulley on the top.
Regards
Samuel
I dont think rope model is possible in creo as per current functionlity.
HI
is there any alternative
You may create the animation with rack and pinion gear connection i guess or with the help of belt however, dynamic caluclation may not be possible.
