"Drainage slope" in Creo?
ptc-5366387
Hello all!
First time poster here and also a recent graduate, so I might not even be using the proper terminology.
I'm making a series of tanks that share walls, with "built-in drainage" since it'll be 3D-printed (see attached file). What I'm trying to add is a slope from the edge of the drain at the bottom of each tank to the edge of all 4 sides of each tank. I want the "rise" of this slope to be 5mm, though this doesn't have to be exact, or I can calculate an angle, etc.
I have absolutely no clue where to start. What function do I use? My "go-to" is Round or Chamfer, but those don't give me control over what the slope is, since this will be rather gentle.
Thank you in advance!!!
Paul
Paul,
I added Revolved surface and Solidify feature in Creo Parametric 3.0 M010.
Martin Hanak
Martin Hanák
7 REPLIES 7
* I should add that my files are created in the full version of Creo, not the student version so you'll be able to open it. Also, to make things easier, I'm putting a screenshot as well.
I think that what I'm trying to do can be best described as a shower drain at the center of a shower stall.
Paul,
Martin Hanak
Martin Hanák
Martin,
You are a saint. Thank you! (I too am running Creo Parametric 3.0 M010).
I see you added the feature in the biggest tank, I'll add in the features for the rest. Could you give me a little bit of a walkthrough on how to do this? (teach a man to fish.. lol)
Many, many thanks again and in advance!
Paul,
I am sorry I do not have enough time to create detailed tutorial for you. I can provide you a couple of tips...
If you want to know how specific feature is built, select it on Model Tree, press right mouse button and use Edit Definition command. Then examine feature section and feature settings.
Revolve feature:
  • it is created as SURFACE feature - Surface button is pressed in feature UI
  • section is related to the hole you made in tank bottom
  • diameter dimension value must ensure that the surface goes beyond the outline of tank bottom (reorient the model to see it from TOP)
Solidify feature:
  • uses Revolved surface as reference
  • is adding material under Revolved surface
Martin Hanak
Martin Hanák
Martin,
One last question. So I created the revolves as surfaces, but can't for the life of me get the solidify feature to work. I can't seem to select the right "quilt"? I haven't worked with quilts before, so I might be completely misunderstanding. I attached my file again, with the revolves added.
Paul,
Revolved surface MUST be in contact with tank bottom. To achieve this, you can modify dimension 15 to 10 and regenerate the model. Then select Quilt and apply Solidify feature.
Martin Hanak
Martin Hanák
Thank you!!!
