radius and chanfer in an assembly
opavot
Hi everybody I just created a revolve in an assembly without any problem , but when I want to add radius or chanfer on the egde I have a problem I can acced to the function normally (radius or chanfer ), but I can't select edge or surface set Do you have and idea to solve this problem ? Thank a lot for your help Oliver
Pro/E by definition cannot add material in an assembly. As rounds and chamfers can do it, they will not work in here. You have to use material cuts instead.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
