screw and nut
rawanaj
screw and nut
my name is rawan i need to know how to machine a screw and nut using ptc creo ( assemble them then show a mechanism for the nut on the screw ) please help me
Welcome to the forum, Rawan.
Thank you for posting your question in the open forum.
Please explain the result you wish to attain.
1. Is the hardware, the screw and nut to be true representations or a simple representation.
2. Is this for the purpose of animation or do you only need the constraints to allow dragging of one of the component and have it follow the appropriate path (rotation and linear).
3. Do you need to drive this with a mechanism servo.
As I explained in the private messages, this motion is not without challenge. It is best if the task is fully defined in order the best help you achieve your goals.
