the proe windows suddenly closed by itself
ptc-2803933
when i making 2D assemble drawing in proe , i insert a main view first ,but when i insert a projection drawing ,the windows suddenly closed by itself without warning or notice ,who can tell me why ,and i have tried many times ,the same situation comes again and again .
I have the same problem. I asked PTC for adive and they seemed surprised, but as usual, offered no constructive advice. Try turning on traceback_log = yes in your config .pro. This will keep a log of the failure so you can send to PTC. Maybe PTC can reply, since they dont seem to care about your problem on this forum. Yes PTC, you do s*ck this bad.
You maxed out the capablities of your computer. It happens to me all the time i just make sure to save often. I acctually have a Mapkey set up with the key sequence asd that automaticly saves and deletes old copies in the working directory. Ive data loged on my computer and it shuts down when it maxes out the procceser. More ram might help and try minimize programs that you have running in the back ground. You could also try to turn down the quality of the display so it is less detailed.
