unexplainable results of an elasto-plastic material modell_ dotted tension
ptc-5349333
7-Bedrock
I need help for my final thesis. I want to simulate a pull-force at a piston rod connected to a valve. I modelled a simplified modell.
The elasto-plastic material modell (second picture) put out some unexplainable results. Does someone already had this problem or can help me please?
In the 3rd picture you can see the results of the linear model
The displacement and forces:Displacement and forcesDisplacement and forcesdotted elasto-plastic simulationdotted elasto-plastic simulationlinear simulationlinear simulationThe same at another try of an elasto-plastic material modell simulationThe same at another try of an elasto-plastic material modell simulation
thanks for your help!
kind regards
Daniel
I already found my mistake.
Actually I forgot to animate the second time step in the results, where I found the explainable results.
skunks
(To:ptc-5349333)
better 2d analysis:
