1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Industry: Print company.
Organization: Programmer. ALD template developer.
2. What product and version are you currently running?
Arbortext Layout Developer.
Ver.12.1.1.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
I would like to be able to output PDF (PS) with the following double cutting guide.
(CuttingGuideB4.pdf)
Registration marks are too close to the plate. Therefore, it cannot be used. I would be happy if this could be resolved together.
Generally, the distance from the plate surface is 3 mm or more.
4. What is the use case for your organization?
Most of the cutting guides used in Japan are double.
Registration marks are close to the plate, and if they are misaligned due to cutting, Registration marks will be printed on the printed matter.
5. What business value would your suggestion represent for your organization?
Output PDF in ALD is standardized.
