ALD/PE - Highcharts Javascript library integration
I hope I am in the correct category for this request.
Is there already a way to integrate the Highcharts javascript library into ALD / PE?
As ALD supports already the MathJax javescript library I thought that it might also be possible to integrate/add the Highcharts javascript library into ALD / PE.
For the moment ALD is relying on chart files (e.g. svg) from external tools which then can be imported in the templates because complex charts cannot be generated in ALD directly.
It would be useful to have direct access to that library in ALD.
3 Comments
SimonTaylor
11-Garnet
Status changed to: Under Consideration
Hi - I'll have a look into this and see whether it is compatible with the way ALD works with MathJax
Thanks!
Simon
GarethOakes
Nice!
jlehnertz
3-Visitor
Thanks Simon for checking.
