We would like to use the "DivisionReference" functionality in the footer of our documents, to display the name of the current chapter. This is very common in books.
However, due to a deficiency in APP functionality, a "DivisionReference" only works if the DTD in use has a title element that is a direct child of the division element in question, which is not true for our DTD (and for many other DTDs).
Note well that cross-reference functionality in APP finds our titles just fine--it is not limited to the direct child relationship.
Please update this functionality to be able to work in a way similar to cross-references.
My case reference: https://www.ptc.com/apps/case_logger_viewer/auth/ssl/case=11385540
