It would be great if it was possible to specify how a colour is published to PDF and separated.
EG: Colour Ctrl stream name = customCol
colour {100,55,0,0}
type named
Publish to PDF using 'Colour Mode = CMYK + Spot Colour'
In Acrobat view the colour separations and any named colours are printed as spot
It would be good to have a drop down in the 'New Custom Colour' dialog to select if you want the named colour to be output as CMYK, RGB or SPOT
