Currently if you install Arbortext Editor only, a double click opens the XML file in Editor. However if you install Styler, the default behaviour is to open XML files in Styler rather than Editor. There are a number of discussions where users would like to be able to change the behaviour.
Currently there are no straightforward methods to control this behaviour.
I propose that in the installer, if both editor and styler are selected to be installed, that the user be given the opton to determine whether styler is the default for opening files or editor only.
Rob.
