Currently, the only way to use any Security features is using Architect. It would be nice to have this implemented in Styler even if its edited source code. The Styler interface allows the inlcusion of the secdesc tag, but strips it upon apply and save because the FosiRescDescItem tag only supports 5 attributes:
Stringdecl
Charfill
Counter
Floatloc
Hyphrule
The only way to get security is to export the stylsheet to a FOSI and edit it manually or using Architect.
