We can specify ALD '3B2' libraries path, using -I:C:/PATH/TO/LIBRARY/lib/ and we use this mechanism to add our own libraries.
As of version 12, APP/ALD provide some extra features - MathJax and OpenType - as '3B2' libraries.But, there is only one '3B2' library path and the default {@}libs is superseded by ours and thus MathJax and OpenType are no longer available...
A possible override is to add MathJax and Opentype to our libraries - but this may cause problem if a given version of those libraries is related to a given ALD version.
It might be interesting to allow to have both ALD {@}libs AND an extra library library path.
