Allow the Arbortext user to specify parameters for HTML Help output
When composing to HTML Help, the composer writes out the hhp file that is to be compiled by the hhc compiler. Currently the appearance of the HTML Help window cannot be changed without decompiling the output chm. It would be useful to be able to set up the wanted parameters in the hhp file (adding a Locate button for example) before running the composition.
1 Comment
ptc-1787870
1-Newbie
Under the HTML tab of the Stylesheet Properties, it would be cool to have a checkbox to toggle the synchronization of the TOC to whatever topic is viewed. I think this may save the end-user from needing to click a Locate button. In either case, I support having an option to define parameters when generating HTML Help output (similar to RoboHelp and others).
