APP's Pseudo fonts are great IF you know what character ranges you are missing, but in many/most cases you do not and its down to the proof readers to spot any unusual characters that may come through especially in multi language work as missing or unavailable in the font represented by an empty glyph box [] or question mark ?
Even character maps can be helpful in this case but again you can only set this up retrospectively once you spot missing chars.
APP has the 'default font' property using <?tfdef> Processing Instruction or fParagraph.defaultFont in JS-FOM, which gives the option of a fallback font should the main/current font be missing any characters.
This is good until you discover your fallback font even Arial MS Unicode or your best guess custom pseudo font might not 'catch all'.
So what would be nice is if this default font had a number of permitted levels to define a set of default fonts as fall-backs.
What also would be a complimentary extra feature is fDisplay highlight on screen/printout of missing chars so they are easier to spot.
This case was presented by a number of our STM Journal producing BPO customers and presented here for voting.
Regards
Chris
____________________
Chris Western,
tformat ltd.
Solutions : Services : Software
