Arbortext Advanced print Publishare:I would like to that '?thyn=2' is not ignored in any situation
I would like to that '?thyn = 2' is not ignored in any situation.
https://www.ptc.com/ja/support/article?n=CS286164
Just like InDesign.
4 Comments
SimonTaylor
11-Garnet
How would you like APP to keep to all the other restrictions in place rather than adding a hyphen? Something in your example had to break a rule, and APP chose to hyphenate rather than leave a line unjustified...
Simon
GarethOakes
If you look at what InDesign did, it actually backtracked and forced a hyphen on an earlier line. This "fixed" the consecutive hyphens problem. However, as you allude to Simon there is not a perfect solution to this. It would require a very complicated set of fallback logic that doesn't currently exist in APP.
myamaguchi-2
3-Visitor
Thank you for confirmation.
I understand this matter.
SimonTaylor
11-Garnet
Status changed to: No Plans to Implement
