Tooltips - are prompts of components inside PVZ graphics. Creo Illustrate uses SBOM structure with CAD components. As ususal, components have attributes NAME, NUMBER. and others. Such attributes can be switched on to display in graphic window. In Creo View or Creo Illustrate if place mouse over component, tooltip are appearing to prompt what this component is: For example, nozzle, bolt isoxxx-yyy and so on. But Arbortext Editor uses cutted information about component structure. Tooltips are not appearing both in Arbortext Editor and any published content like WEB, HTML or Arbortext Content Delivery. For my opinion, such functionality may improve illustrator and end user performance. End user will see names of componens just on the picture, without neccessary pick on hotspots. Number of callouts may be descreased.
