When using a custom DTD and opening text content in Arbortext from Windchill SIM on Publication Section level it results in the runtime wrapper object RDEWrappar around the elements in Arbortext. After upgrade from Arbortext 6.1 to 7.0 has the handling of attributes become better when opening documents in this RDEWrapper mode
Wish: That it should be possible to update all attributes defined in the DTD when opening All Topics (with the RDEWrapper around)
See attached power point for more details about the desired end result
