Can the error message "The selected document ‘tite##### (BDAmap) {x-wc://file=#####.xml}’ could not be checked out" be improved to indicate to two users to synchronize their workspace in Windchill PDMLink 10.1 ? | |
Description |
Applies To |
The current error message leaves users in speculative situations. It would be better if I user would receive an error message like: Please update your workspace. OR : The object is already checked out by User XYZ...
Event better there was an active push information to refresh the workspace state if documents geht checked out in commonspace - but this idea seams to be an performance issue. So I would be happy with a better error message, which gives the user the chance of doing the correct next step.
This idea was discussed with Support / Develepment in Case 11854996, SPR 2217818, CS166806 (a similar case in SPR 1193531).
