The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Centered headings
Centered headings
When composing centered text - generally, headings - if the text flows onte 2 lines, FOP seems to balance the line length :
Same text composed by APP :
Of course it's possible to balance the line programmatically, but an built-in option would be interesting !
4 Comments
GarethOakes
I think it would be a helpful feature but I'm sure we already solved this with try tables in the past.
jtripoz
3-Visitor
Hi Gareth,
You're right, it's possible to do it with try tables. I made it when we started using APP, to make headers with a 'potatoe shape' when on 3 lines (the middle line had to be a bit larger than the 1st and 3rd). But it was a little bit tricky...
Here I would rather measrure the whole text, measure a space, split the text on spaces, measure each chunk then decide where to fold, then add a <br /> at this place and 'mark' the paragraph to not process it again if reformating.
But... a built-in option would be easier to use !!
I've just had a look to InDesign CC 2019, it has the option :
J.
GarethOakes
You've got my vote - I think it would be a cool feature to have baked in, particularly if there some optimisations made that improved the processing speed over the trytables algorithm.
SimonTaylor
11-Garnet
Status changed to: Under Consideration
