Cutting in 2D geometries in IsoDraw
0 Kudos
It would be nice if it could be possible in IsoDraw to cut in 2D geometries like it's possible to cut in 3D geometries.
E.g. if you're using 2D library objects, like a hand, and only need the fingers to be shown, then all the rest can be cut away.
BR Jens Holme Bjørneboe
DFM engineer
Widex A/S
3 Comments
TimHarrison
1-Newbie
After you add a library item to an illustration you can just ungroup it to make it editable. You can then use standard tools and methods to edit the lines.
Hope this helps.
jbjørneboe
1-Newbie
It actually works - nice - but - the library parts I'm interested in (hands) are made from long Bézier lines. This still not adresses the issue of cutting in 2D geometries. For me it's a new option of handling, though.
olivierlp
Community Manager
Status changed to: Archived
