Hello!
In the DCF, I can define - for example - many element- and attributeoptions, such as protecting or hiding elements.
However, those options are bound to an element.
We'd like to have the chance, to define an XPath instead of element/attribute.
For example:
Xpath: author/p hidden=yes
should only hide p-Elements with parent author. All other p's should be present unless somewhere declared different.
Thank you,
your WindchillTeam@DATACOPY
Note for PTC: Legacy E8223759
