DITA "Update reference" action does not work with Windchill
The action should update the navtitle and other attributes. It works fine when storing DITA on disk. Users who migrate from disk to Windchill / other CMS will consider this a regression.
The action does nothing when objects are in Windchill / other CMS due to performance issues. There is also no message indicating that the action is disabled.
Documented here:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS58885
The Completeness Check used to skip opening topics when using Windchill but it was improved in 6.0. However, the "Update references" was not enabled for Windchill at that time.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
