When a figure is inserted with reuse the default graphic id is:
<figure id="F0001">
Whereas chapter 3.9.5.2.1.2 page 22 para 3 gives a recommended set of references as a Business Rule Decision which must be made for the format of the id. The present example, which is automatically inserted, does not follow the recommendation in the spec for the format of cross reference attribute id. It should appear as follows:
<figure id="fig-0001">
