Enhance pdfs created by Isodraw to be searchable
To cut down on publish to pdf time for our schematics, we are creating them as pdfs to remove the time required to convert them to a different format. When you place an eps, or pdf file in Isodraw, then export it as a pdf it will not be searchable. If the original pdf is searchable then the outputted pdf will also be searchable.
1 Comment
SimonTaylor
11-Garnet
Status changed to: Under Consideration
