Enhanced baselineShift
0 Kudos
Autoleading mechanism doest not consider baselineShift.
If we want to align correctly inline equations whose baseline is not at the v-center of the image, it is possible to move them vertically but... only graphically, 3B2 still consider the image without the baselineShift so autoleading might not work as expected.
Adding a option to <?tvs > PI fStyle.baselineShift which would instruct 3B2 to consider the baselineShift in its autoleading mechanism might solve this.
6 Comments
GarethOakes
Hi Jacques, I understand what you're saying but I believe tvs/baselineshift is intended to work as you describe. It removes the content from the usual flow, hence the baseline (and x-position of following text) should not be adjusted due to tvs/baselineshift. In other customer templates we have aligned inline equations as you mention using TeX commands and this did work with autoleading correctly. I can try to dig out some code if you like.
jtripoz
3-Visitor
Hi Gareth,
I would be pleased if you could give me a simple example showing how to do this in TeK !
But I think adding a option to tvs would be easier:
<?tvs 10pt> or <?tvs 10pt, 0> => work as usually, just move graphically
<?tvs 10pt,1 > => move the baseline graphically but consider the shift for autoleading process
And of course a new property in fStyle, eg fStyle.baselineShiftAutoleading => if 0 (default) do not consider the shift for autoleading - as now - if 1 => consider it.
J.
GarethOakes
Try something like the following within a <?tal=1> paragraph:
<$>\vskip-15truept\colorbox{red}{123\over123\over123}<$>
The \vskip command will shift the baseline while enabling the autoleading to work correctly. You can adjust vskip to positive or negative values.
jtripoz
3-Visitor
Thx, I'll try !
SimonTaylor
olivierlp
Community Manager
Status changed to: Archived
