Currently Arbortext and ACM fail to update the dependent topics contained in a DITA map or DITA bookmap to the latest version in the content management system if other users have updated a dependent topic since the last time the current user has opened that topic themself. This seems to be a failure to adhere to at least the spirit of DITA, if not an full-fledged failure to support the standard.
Users should be able to open a DITA bookmap and select File > Update Object and have an open to have all dependent objects updated, as well.
