The 1st attached screen capture (PDF output) shows the chapter-toc as styled by the Standard DITA Styler Stylesheet (ditabase.style):
The 2nd attached screen capture shows sfe:TocEntry1_ChapterTOC element. The gentext adds a diamond-shaped bullet before the entries. We want to have a solid, round bullet, not diamond-shaped. The chapterToc elements should be UFEs so that customers can easily change style characteristics:
