When publishing an HTML file output from .dita file, which contains a table format, by Arbortext Styler, the value of the column width (as in "colwidth" attribute) of the table is fixed.
There is no assigned value in "colwidth" of the table in .dita file, however, the "colwidth" of the table in the HTML file output is assigned in 480 automatically.
We are hoping that this fixed value can become adjustable in order to achieve more flexible publishing.
With this condition, we consider that the content gets left-sided in full screen display (FYI, the browser is IE 8 or later), and it is not the best for multiusing of the content.
