The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Graphic file from the Windchill in the Styler generated text and PDF/WEB publishing
In the generated text in Styler I would like to use a graphic file, which is stored in the Windchill (Arbortext Content Manager) Library.
This method (the change "pathname" attribute to the graphics logical ID from Windchill)  described in the document CS79314 (https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS79314)
works only in the Gentext window (see Add Before picture) but not in the PDF or WEB output.
We want to use these graphic files from Windchill also in the book title, the page region etc. and then publish it to the PDF or WEB output
Thanks for your UP voting
Jana Hubackova
