How to create an enhancement request or product idea for PTC products
0 Kudos
The request I'm seeking for improvement to the PTC Product Creo is that when inside the Assembly type file and looking to explode objects inside that assembly that parts by dropping a new object in fall in equal offsets of the part that was drop in before that object.  Currently I believe the Objective that is being drop in is tied to the last part that was drop in and drops in multiples by feature number of the last object drop in.  How it will look as first object is Default location.  Second object location is space equal times the feature number 1x.  Third object location is then driven by the second object drop in and is then space by feature number of 2x of the second object and not 2x of the first object, making not equal spaces.  Fourth object location is then driven by the third object drop in and is then space by feature number of 3x of the third object and not 3x of the first object, making not equal spaces again.
This makes taken pictures to use for documents longer to fix exploded view to be equally spaced out.
2 Comments
jadams
1-Newbie
olivierlp
Community Manager
Status changed to: Archived
