There are rather many limitioatns manipulating objects in Arbotext when selecting Open --> Open all topics in Arbortext from Windchill SIM
For example it is not possible to do
- Check out all objects for a non dita dtd
- Use the Print function in the file menu in Arbortext
- Revise object by right click or from the Object menu
