Improved AutoCorrect Feature
I ran across this issue with autocorrect.
In some types of data or texts, authors sometime want to use a lower case 'i'. We found that autocorrect *always* changes this back to an upper case 'I'.
The only way to fix this was to edit XML source or just turn off the feature.
Other products (notably MS products) will detect if you have reverted the previously autocorrected text back and assume you meant to have it that way.
I suggest PTC implement a similar algorithm to ensure that users can use the product with autocorrect turned on, but also allow them to effectovely undo the autocorrect if they meant to have the text the other way.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
