Currently, Arbortext does not scale correctly when used on high-density monitors which makes the user interface slightly blurred. Windows allows to manually set font scaling for Arbortext to improve compatibility, but when using these settings the text insert cursor (which is not programmed as a standard Windows interface item) becomes shifted by a few characters. This makes it impossible to use Windows compatibility settings for Arbortext on high-density screens.
