When using to use SMA and FOSI to publish using print composer the program would convert all the cgms to EPS and save them locally. This would speed up the second and third publishes of the same book. We now use TIA and APP is there a setting to change to allow the caching of the images to be reused on second and third publishes of the same document. Publishing anything takes a long time. |
